2-3 Volumetric Effects, it is possible?
  • 2-3 Volumetric Effects, it is possible?
    It is possible to render an image using two types of volumetric effects at the same time?
    Like, render using VRayEnvironmentFog for the closer lights to the camera and VRayAerialPerspective for the general environment?
    Or I do have to break in 2 passes?
    In the render settings, the Environment Volume has just one input.
    You can use a container for the VRayEnvironmentFog. Create an object, apply a VRayMtl as a Surface material, and set its opacity to black, afterward set the EnvironmentFog as the object's Volume material.
      I am going to try. Thank you
