ACES shaderball scene for Vray 5
  • ACES shaderball scene for Vray 5
    Hi
    I updated my shaderball scene for ACES and Vray 5, all maps and HDRIs are converted to ACES. You will need to setup Maya to use ACES OCIO for this to work, I'm using ACES 1.2 here (and if you don't use ACES, there is a second download link below)
    ACES Shaderball here,
    https://drive.google.com/file/d/1HeN...ew?usp=sharing
    The shaderball is sub-D and has good UVs, different lighting setups are included for look-dev. Enjoy!
    If you don't use Vray 5 or ACES, here is the same scene for Vray Next and sRGB
    https://forums.chaosgroup.com/forum/...-for-vray-next
    Click image for larger version  Name:	003.jpg Views:	18 Size:	284.9 KB ID:	1075587
    Click image for larger version  Name:	001.jpg Views:	16 Size:	1.07 MB ID:	1075590
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
    Though I'd take a look, I get a missing OpenColorIO configuration file error
    C:/users/Muhammed/Documents/aces_1.2/config.ocio
    Working space menu selection is not available ACES -ACEScg
      stezza Hello!
      You will need to setup Maya with OCIO .. Download ACES 1.2 here
      https://github.com/colour-science/OpenColorIO-Configs
      Then point Maya to use the config file
      If you don't use ACES, I linked another download for typical sRGB scene file
      I will update my post with this info
      Best,
      Muhammed
      Muhammed Hamed
      chaos.com
        I found out that when i have the the OCIO config path set to the Aces 1.2 config file, theres quite a big lag when you select textures in the hypershade and for the attributes to show up. Same lag you get when creating your own rules. This is because the config files contain so many variants of rules.
        Have you edited down your own?
        Also maya 2022 default ocio config doesnt seem to contain 'Utility sRGB texture ' etc
        e: info@adriandenne.com
        w: www.adriandenne.com
          Interesting, It doesn't lag for me at all
          I guess the single threaded performance of my 5950x helps here, it is nearly double of your CPU
          I'm using the native config.ocio file right now (needed for some testing)
          But I created a simpler version with only the IDTs I need, you can download here
          It will be very helpful in your case, backup your original config.ocio
          Muhammed Hamed
          chaos.com
            exactly what i needed, you are a star Thx buddy!!
            Seems like I'm rapidly getting to the point where I'm needing a new CPU
              You are the best Muhammed_Hamed , I can't wait to check this out!
              My Artstation
              Whether it is an advantageous position or a disadvantageous one, the opposite state should be always present to your mind. -
              Sun Tsu
                Muhammed_Hamed awesome! I need this for 3dsMax + Vray.
                Does some guide like this exists? I will convert this scene to 3dsmax..
                  Hi Filib,
                  I have a 3Ds Max version of this scene here
                  https://forums.chaosgroup.com/forum/...ene-for-vray-5
                  Guide for what exactly? moving assets from Maya to Max?
                  Best,
                  Muhammed
                  Muhammed Hamed
                  chaos.com
                    Originally posted by Muhammed_Hamed View Post
                    Hi Filib,
                    Best,
                    Muhammed
                    Oh well thats good.
                    Im really interessted into Aces Workflow with 3dsMax and Vray. Not sure about the post in Photoshop + OpenColorIO.
                    Do you think ACES Workflow is for digital AND printmedia? I mean of after getting the render i have to apply icc and right Colorspace for printing but yeah a big topic.
                    This 3dsmax Thread with ACES is something i was searching for! Thanks for the work mate!
                    Regards,
                    Philipp
                      Yes, 100%
                      More discussion about this here, you will see examples and comparison
                      https://forums.chaosgroup.com/forum/...ation-vray-gpu
                      And if you have questions about something feel free to tag me
                      Best,
                      Muhammed
                      Muhammed Hamed
                      chaos.com
