VFB shortcuts
  • VFB shortcuts
    I thought this might happen, but when ipr rendering and interacting with geo in the scene etc, the vfb shortcuts keep overriding mayas keys, so for example i might want to rotate an object a bit, then i find the vfb window slightly in the way, so i move it over, then when I think im clicking 'E' to rotate, instead it enables the A/B option in the vfb. Could we have an option to disable the hotkeys?
    e: info@adriandenne.com
    w: www.adriandenne.com
    yeah this is getting a bit annoying
      also when hitting ctl+s to save scene, VFB wants to save it's settings this way.
        its driving me nutso, forgetting that i have the vfb window selected, then moving mouse into the main viewport and hitting the flippin shortcut.
          is there any way this can be sorted? Driving meee crazzzzzzy.
            Hi guys, thanks for the input. I've made a feature request to change/remove the VFB shortcuts for developer investigation. It is logged under ID number: VMAYA-9953.
            Nikoleta Garkova | chaos.com
              hi thanks, just an option in settings to turn it on or off would be fine as long as the setting is remembered next time you load maya etc.
