I'm making neon tubes.
Was hoping to use renderable curves, but when I apply a refractive material they tubes are rendered as a solid tube.
I'm wondering if there's some way to render the curve so that it is a hollow tube instead.
Failing that, is there any way to render a single polygon as if it had thickness, preferable without having to extrude it. Something at the attribute level, (like rounded edges).
Thanks in advance
Thanks in advance
