Nested Vrscenes & Light Select
  • Nested Vrscenes & Light Select
    Hi everyone,
    I'm wondering if there is a way to output the Lightselect elements saved inside a vrscene file when referencing it via the VrayScene Manager. Right now I'm able to create a new Lightselect element inside the Maya scene and connect it to any given instance of a vrscene, which will output an AOV containing all the lights in that scene file. But it would be really useful to be able to render the contained Lightselect elements or access the nested lights.
    Do you know if it is already possible using a workaround?
    Thanks!
    It is not possible for already exported .vrscenes, I'm afraid. The lighting setup should be done in the Maya scene.
