Skydome with VRayGeoSun
  • Skydome with VRayGeoSun
    So what is the correct way to combine the skydome HDRI with the GeoSun?
    I need to have some clouds in my animation which is using physical sun but this on it's own gives you the flat blue sky which I need to replace with clouds.
    I dont necessarily need the hdri to effect the scene as the light from the VRay sun and sky give a good result.
    How is this set up?
    Many thanks
    From what I understand you simply need a cloudy background without an effect on the scene's lighting? You can do it with a VRayDomeLight which has its Affect parameters (diffuse, specular, reflections) turned off; this way it would act as a background.
      One of those palm slaps to the forehead moments...many thanks
