GPU : "Material select" render element
  • GPU : "Material select" render element
    is there an ETA on when the Material Select render element will be available for gpu?
    e: info@adriandenne.com
    w: www.adriandenne.com
    There isn't, however, work for the element's support is in progress.
      ok thanks for reply.
        Hi everyone,
        Reviving this thread. There are two methods to get a material select already and I was wondering if any of those is suitable for you.
        One way is to use Light Path Expressions, basically a beauty (C.*) with a material label. For example if the material label is "myMaterial', the expression C.'mmyMaterial'.* would give you a material select for the material(s) with that label. Note that m is pre-pended to the label name in the expression.
        You can read more about LPEs here: https://docs.chaosgroup.com/display/...th+Expressions
        Another method is to use Cryptomatte in "Material name" mode and just mask out the beauty for any material.
        Also, in V-Ray 5.1 the Cryptomatte now works with progressive sampling.
        Would either of this work for you? It essentially produces the same result as the Material Select.
        Alex Yolov
        Product Manager
        V-Ray for Maya, Chaos Player
        www.chaos.com
          yeah i just had a quick go of the cryptomatte masking yesterday...v cool thx mate
