USD object not showing in the RENDER
  • USD object not showing in the RENDER
    Am I doing something wrong?
    1) I created a sphere with a v-ray applied shader and just a dome light.
    2) I export just the sphere using the <File <Export Selection ---->USD with V-Ray materials Exporter- selected
    3) I re-import the USD using < Create <Universal Scene Description (USD) < Stage From File.
    The sphere LOADS ok, but does not show up in the render itself. The sphere is invisible in the vfb.
    It is something Am I missing?
    best
    Seems to be working fine on my end. I presume you've deleted the original shapes, which breaks the referencing. Try saving the file prior to exporting the USD and afterward import it in a fresh scene. For more information, check this detailed guide about the USD Workflow. Also, here are the supported features when rendering USD with V-Ray.
      Hi Hermit,
      I am using just a basic sphere with a V-Ray Mtl applied.
      When rendering, the script editor states log
      // Error: line 1: V-Ray : VRayScene: File "C:/Users/kandor/Documents/maya/projects/default/scenes/test2.usd" not found! //
      The original geometry still in the scene and the USD imported too.
      but When I press render. Does not show the sphere USD
      the original sphere I hid in layer
      Saving preview here.
      Maybe I do have to activate another plugin?
      Thanks a lot for help with this issue
        Now is working. I deleted my preferences folder. (to get a refresh) from default.
        And now is working. I probably had something inside getting conflict.
        Thanks
