Is there a way to save an animated IPR render?
  • Is there a way to save an animated IPR render?
    Hello everybody!
    I´m trying to render an animated scene, but when i render using normal render, my scene is not showing up the configurations that i wanted to have. Only when i render using IPR, the scene matches with my configurations. Im using a render layer for this scene. So i was thinking if there is a way to render using IPR and save this animated scene. Could somebody help me, please?
    It would be a better idea to determine why your sequence is not saving as seen in the VFB. Could you attach some screencaps of the differences? Are you saving multichannel images? An often mistake is to forget to check the "Save Color Corrections to Raw Files" option in the Image Format Options (Render Settings>Common> Image FIle Output). If by configurations you mean your Render Layer setup, maybe you could send the scene via the contact form so we can take a look?
