Simplified .ocio file?
  • Simplified .ocio file?
    I came across a simplified .ocio file on the forum recently. I can't find that thread. Could anyone link it up here?
    thanks in advance,
    Karol
    My Artstation
    Whether it is an advantageous position or a disadvantageous one, the opposite state should be always present to your mind. -
    Sun Tsu
    Here you go
    https://drive.google.com/file/d/1TTf...ew?usp=sharing
    Let me know if there are any missing conversions you are interested in, and I will add them
    Best,
    Muhammed
    Muhammed Hamed
    V-Ray GPU product specialist
    chaos.com
      Thanks a lot Muhammed!
      My Artstation
      Sun Tsu
        Hi Muhammed, sorry for bothering you again on this topic. Is it normal that all hypershade is much significantly darker using ACES color space management?
        My Artstation
        Sun Tsu
          + should I keep my viewport in srgb ACES or RAW ACES?
          My Artstation
          Sun Tsu
            Hey Karol, Viewport should be ACES sRGB(like the frame buffer and material viewer), and the material viewer seems to be fine to me. it is a bit darker compared to usual because of the contrast the ACES sRGB Output Transform uses
            Can you show me the settings for the file node for this material, to make sure the setup is all correct?
            On another note, I'm updating the ACES docs now. I will ping you when this is ready, it should answer most of the questions on the workflow
            Best,
            Muhammed
            Muhammed Hamed
            chaos.com
              Hi Muhammed_Hamed , sorry for the late reply.
              I am still trying to get my head around ACES.
              At work I am doing it with alternative, less invasive method using AMPAS tonemapping inside VFB and it works relatively fine.
              At home I followed the official docs, pointing Maya to downloaded .ocio file etc. but I am having big issues with colors.
              1. Color picker, never matches hypershade sample preview. (attached example)
              I believed in 3ds max videos regarding ACES people use a VRay node for color values with changed color space. Does it have to be done in Maya as well? I got no luck with VRay user color node.
              My Artstation
              Sun Tsu
                Maybe this is causing the issue.
                My Artstation
                Sun Tsu
                  https://community.acescentral.com/t/...-question/3769
                  I believe that person has the same issue, I've read through it but I feel kinda lost in all of it.
                  My Artstation
                  Sun Tsu
                    Hey Karol and happy new year
                    I'm making a video on ACES setup in Maya, I will ping you when it is live. there is also an updated to documentation soon about this
                    About color picking check my post here
                    I hope this helps until I post my video, or if you have specific questions let me know
                    Best,
                    Muhammed
                    Muhammed Hamed
                    chaos.com
                      Hey Muhammed, happy new year to you too!
                      I am really looking forward to it, as I am trying to push ACES into our workflow but obiously I want to understand everything as best as possible before trying to explain it to others.
                      Will look into your post now, thank you very much.
                      Much appreciate it!
                      best regards,
                      Karol
                      My Artstation
                      Sun Tsu
                        Good luck!
                        I spent time on adapting my previous 2 studios to ACES, this topic touches on quality so it was worth the effort at the end, and I learned a lot from this experience. I know that both places are still using ACES until now which makes me happy
                        This is an older video on ACES in the frame buffer,
                        https://www.youtube.com/watch?v=01KgYgvANmg
                        Which I will cover briefly in the new video as well
                        On another note, Color picking in Maya and the native color management are both great. Much better than 3Ds Max, as you have control over what you use, 3Ds Max actually doesn't have any native color management.
                        Best,
                        Muhammed
                        Muhammed Hamed
                        chaos.com
                          Thanks!
                          My initial experience with ACES is rather positive, so far I did two projects with it and I love the way colors blends together and everything has that extra "pop up" effects which was super difficult to get with sRGB.
                          Also the burn is so, so much easier to avoid.
                          The biggest challenge so far is to match textures from photoshop to what you see in the actual render. Everything is much darker and saturdated to the extend I often had to boost their exposure / desaturate them.
                          I also find the lights temperature challenging too.
                          Here are some samples and the settings I've used. I have a feeling that I still mess something up.
                          My Artstation
                          Sun Tsu
                            Everything is darker in both viewport and VFB....
                            My Artstation
                            Sun Tsu
                            • #15
                              Morning Karol,
                              This looks fine to me, I think your settings are correct. The ACES look has more contrast by nature, hence you see the difference
                              You will need to adjust your lights/exposure to be brighter
                              And there is a way of having a perfect match for a logo/texture if needs be, keep in mind that all the ACES transforms are reversable including the tonemapped version. I will touch on this in details in my video
                              And in the link above, I explained the part about matching a logo. Basically you need to load it with an IDT ACES sRGB in stead of the usually Utility sRGB Texture
                              Best,
                              Muhammed
                              Muhammed Hamed
                              chaos.com
