EXR Metadata
  • EXR Metadata
    How do i read the EXR Metadata from Vray? I know Vray is storing a lot of info in EXR files.
    https://linktr.ee/cg_oglu
    Ryzen 5950, Geforce 3060, 128GB ram
    I think it depends on the software, in which you load the .exr (i.e. in Nuke, there's a metadata rollout in the Read node). I'm aware that it's possible to compile a standalone reader through the Open EXR itself. Otherwise, here's a thread with a similar question and sample software - you may give it a try.
      Thanks for the info.
      This could be a good addition to the VFB if you point the history to a directory of EXR files.
      Or the Chaosplayer.
        open in photoshop, go to file then file info near the bottom and its all there in raw data
          @matthew999 ​ No thats not the metadata.
          There is no info like which maya file this EXR is coming from. No data about samples or camera.
            ChaosPlayer is doing it with shortcut "M"
            Thanks Alex!
              You sure mate. When I look in the string it has all this info, let me paste tomorrow when in front of pc.
              defo there for me in ps, maybe its because i use exrio plugin
              attached is a copy paste into text doc exr meta data from ps.txt
                Thanks for the info. But we cant use this plugin.
                We cannot make sure this plugin is used for all our developers.
                  ah fair enough, photoshops native plugin for exr is absolutey uselss , and as u have experianced it doesnt support exr meta data
                    Adobe is consistently about five years behind the curve when it comes to the CG industry, it's shocking.
                      Totally agree. I have been using plugins for exr for over 10 years first proexr and now exrio. Iirc abobe outright think that multilayer Exrs are the incorrect use of exr and they are right. It's like they believe the earth is flat or somin
                        The fact that Photoshop STILL doesn't know what an alpha channel is tells you everything you need to know about their interest in serving the VFX industry.
