execute Script at render time
  • execute Script at render time
    Hi there,
    actually i work on a .py script that will load the next file of an .obj sequence according to the actual frame.
    That works fine in Maya Viewport, but i don't get it to work while batch rendering with vray.
    I use a mel command in the render settings, common tab, Post Render Frame MEL
    Is there someone who can tell my why or whats a better way...?
    Thank you a lot!
    Post Rende Frame MEL should work with batch rendering. However, it seems unnecessary. Why don't you convert the .objs to .vrmeshes via the Ply2vrmesh tool and load the sequence in a VRayProxy?
      using Post render frame MEL gives vray returns "path to a reference is changed, its's safer to abort rendering" (just the words i remeber, not the exact message).
      But anyway, the workflow with ply2vrmesh should also work.
      Maybe you have a fundamentally better idea...:
      My goal is to render a water simulation.
      I want to use an external program to simulate that gives me .bgeo or .vtk as output. Included are the coordinates of each particle.
      Is there a way to render this without the meshing intermediate step?​ I found already the VrayMetaball, but its really slow to render
        Originally posted by t_b View Post
        My goal is to render a water simulation.I want to use an external program to simulate that gives me .bgeo or .vtk as output. Included are the coordinates of each particle.
        Not that I know of.
