How do I do an opacity map when I use Udim method?
  • How do I do an opacity map when I use Udim method?
    I worked on the texture in the udim method
    I worked on 1001 to 1005.
    What should I do when the opacity map is included in the 1005 tiles only?
    I pulled the file in Png format.
    What should I do?​
    You need to use the wildcard <UDIM>. Check docs.
