Render not matching frame buffer
  • Render not matching frame buffer
    So I am running into issues with the frame buffer not matching the final render. It's almost like a slight color shift and exposure. Just guessing here. I have saved it from the frame buffer and also ran a final render jpg, png, and an exr.
    All seem to match but doesn't match the VFB. I'm running the latest vray 2.2 I think with Maya 2024. Any ideas ??
    Is your VFB set to sRGB or OCIO?
    If OCIO - is it plugged into the config file?
      Make sure the image viewer you are using has similar Display Correction settings as in the VFB. If using an OCIO config, make sure the viewer has it aswell.
        Sorry for the delay. I did end up fixing it and the issue was not Vray or even Maya. It was Windows 11 color calibration being wrong and also there was something checked in Photoshop that shouldn't have been.
        Thanks for the info and quick reply by the way.
