transparent textile
  • transparent textile
    I would like to make a textile like the one on the link: http://www.crdecoration.com/blog-dec...03/rideaux.jpg
    what would you recommend ? SSS2 or not ? only transparency or something like that ?
    regards,
    olivier
    www.mirage-cg.com
    vray 2 sided
      thank you. But i can't really see the reason why you would use 2sided aside the fact that it is for single sided objects. the problem is more to get the right effect for transparency and translucence...
      www.mirage-cg.com
        2 sided creates the effect your after , its a faster form of translucency made for objects like lamps, curtains, leafs and so on.. I believe theres alot of info regarding 2 sided in this forum.
