render region command line in linux, with a vrscene
  • render region command line in linux, with a vrscene
    Trying to do a render region with a vrscene
    using the commmand in linux:
    vray -displaySRGB=1 -reg="185,395,179,370" -scenefile=tmp_defaultRenderLayer.vrscene
    tried aswel:
    vray -displaySRGB=1 -reg=x185y395x179y370 -scenefile=tmp_defaultRenderLayer.vrscene
    Could anybody tell me what the right command is ?
    (i'm thinking of just wrapping it and connecting it via mel, so i can do region renders from within maya)
    Thank you,
    O.
    It should be
    Code:
    vray -displaySRGB=1 -region=185;395;179;370 -scenefile=tmp_defaultRenderLayer.vrscene
      I tried that one before too..
      vray -displaySRGB=1 -reg=185 ; 395 ; 179 ; 370 -scenefile=tmp_defaultRenderLayer.vrscene
      [2010/Mar/22|11:06:49] Reading configuration from "/mnt/sa48-2/tools/binlinux/vray/vray_1.50.00.10915/vray_plugins/bin//vrayconfig.xml"
      [2010/Mar/22|11:06:49] error: Nothing to do; use -sceneFile, -server or -cmdMode options
      [2010/Mar/22|11:06:49] Closing log - 1 error(s), 0 warning(s).
      395: Command not found.
      179: Command not found.
      370: Command not found.
      Think the problem is that ; does adding commands, so linux sees this as "adding" a new command after the other..
      like: ls;pwd
      this will do Ls, then Pwd ....
      O.
        Just saw the typo:
        (but same problem)
        [2010/Mar/22|11:17:46] Reading configuration from "/mnt/sa48-2/tools/binlinux/vray/vray_1.50.00.10915/vray_plugins/bin//vrayconfig.xml"
        [2010/Mar/22|11:17:46] error: Nothing to do; use -sceneFile, -server or -cmdMode options
        [2010/Mar/22|11:17:46] Closing log - 1 error(s), 0 warning(s)
          Hm, try adding quotes around "185;395;179;370"
            Yeah, that rendered a little square, so seems to work,
            going to do some tests, curious how it correlates from maya's region to vray's region.
            Thank you,
            O.
              Great, works, thank you.
              O.
