rush render queue duplicate frames / job / loop
  • rush render queue duplicate frames / job / loop
    hello.
    i'm experiencing a problem with Rush render queue and Vray. it seems as though rather than sending a single frame to a designated server. the entire job is sent to all servers...
    has anyone experienced anything similar with Rush and Vray? frames seem to be delegated properly with other renderes. i've attached a sample log file.
    thanks,
    stz
    Hey - are you using or switching to a nightly build? If so this might be worth taking a look at, although the problem occurred in muster, but it was the same general issue.
    Animation should be turned on for a file that is getting batch rendered. Perhaps the rush packets aren't getting the correct start and end frame, and thus are trying to render the whole sequence?
    Jens
      JENS!
      thanks for the response. the farm i'm using has the official release -- not the nightly build. i posted a similar thread in the public forum, and i believe we've got it worked out although i won't know for sure until later this week.
      here's that post:
      http://www.chaosgroup.com/forums/vbu...highlight=rush
