Im trying to use make a vrscene from maya and render it with the standalone command prompt. everything is good so far i can make the vrscene file and launch the command render and i see the vfb opens and the image is rendering.
however i look at the options for output filename and I'm confused how to specify the save file output.
imgFile="fileName"
if i dont specify the filename i guess it renders to some temp memory directory and gets deleted then?
i try to just name some file "WhereMyFile." but it doesn't seem to save the file anywhere on my hard drive that i can find?
so I have a somewhat complicated naming structure that we use in maya to sort our renders can this be mimicked in the vray standalone or something similar.
so ideally we use
%s/%c/%l
so scene file / camera / render layer.
so for my vray scene i might have to set this up manually im guessing>? but how to?
imgFile="fileName"
so ideally we use
%s/%c/%l
