location of DR logs when running as a service?
  • location of DR logs when running as a service?
    Hello,
    I would like to start using the spawner service, but I cannot seem to locate any log files it creates (if any). Is there a way to pipe the output of the log into a file somewhere when it is running as a service? Also, I would like to RFE that the 'install as service' lets you select which user that service runs as, since I have to change it by hand every time.
    Thanks
    MD
    ah ha, I just found the log in C: root. Does this file ever get deleted, or do I need to delete it myself?
    MD
      Do you mean the log file for the spawner service? I think it is just appended to each time the service is run.
