So do you still need to run the render slaves when DR when the spawner is running?
Spawner question
can you actually do it?
In my case if the service is running, the slave won't work if launch manually. The dos window appears then closed automatically.Portfolio: http://www.cgifocus.co.uk
Hello Stezza,
If you have registered V-Ray slave as a service it will start automatically and you don't have to start it manually. If you try to start it manually, while you have it running as a service, you will get a message that the port 20207 is already used and it will exit.Best regards,
Zdravko Keremidchiev
