render elements
  • render elements
    Would it be possible to have a "fur" render element? or is it a better practice to do it as a seperate render layer for compositing?
    Havnt done much fur work!!
    Chris
    You can use the material select element to extract the hair into its own element, if you need it.
      so how would you do that with Vray fur?
        Just assign a separate material to the VRayFur object, and then link that material to a "Material Select" element.
