maintaining Vray builds with workstations and the render frarm?
  • #31
    Hm ok. However for some reason it looks like the config file is not loaded correctly...
    • #32
      Yeah this is what I am thinking too. But only when running the install.bat file using the PSTool command.
      Just running the install.bat file locally on the render node works and installs fine.
      • #33
        Are you running it from the same folder where the xml_mya2012_x64.xml file is located? If you don't specify a full path to that file, the installer will attempt to load it from the current folder.
        • #34
          Yeah the xml file is located in the same folder the install.bat file is located. (on a shared drive called z:\installs\)
          I can try and specify the full path to the xml file and see if that makes a difference.
          Cheers,
          Richard
          • #35
            I tried editing the .bat file run this command with a specified path to the .xml file
            Code:
            vray_adv_20004_maya2012_x64.exe -gui=0 -configFile="Z:\installs\xml_mya2012_x64.xml" -quiet=1
            But still the same error occurring.
            • #36
              Well, for the next night build tomorrow I added an error message if the configuration file cannot be loaded, so it may shed some light on what's going on.
              • #37
                Ok great. Thanks Vlado.
                • #38
                  I've been able to use Qube 6 to push run the prompt/xml/quiet installer to the workstations. Is there a way to also send the license server information? I can't find a file that has the server and port info, and I'd like to just copy that to the machines.
                  • #39
                    I ran into the problem with the install / mel modification when updating our V-Ray last Wednesday on all our machines with PsTools and had to VNC into each machine to make sure it all went through. That one indeed needs to be fixed.
                    Any chance we could also get an option to force an uninstall of V-Ray via commandline?
                    Best Regards,
                    Fredrik
                    • #40
                      The file is called vrlclient.xml and its location can be specified with the VRAY_AUTH_CLIENT_FILE_PATH environment variable; by default it is in the folder C:\Program Files\Common Files\ChaosGroup
                      • #41
                        If you have a default installation, you can do this with the following command (all on one line):
                        Code:
                        "C:\Program Files\Chaos Group\V-Ray\Maya 2011 for x64/uninstall/wininstaller.exe" -uninstall="C:\Program Files\Chaos Group\V-Ray\Maya 2011 for x64/uninstall/install.log" -uninstallApp="V-Ray for Maya 2011 for x64" -gui=0 -quiet=1
                        Of course you will need to replace the correct Maya version and the folder paths if they are not the default ones. (The file install.log is a text file that contains a list of all the changes that were made by the original installer, if you are curious).
                        • #42
                          Seems I cannot even get the install to run. Think the issue here is PSTools.
                          When I try running the script I just get this:
                          Code:
                          C:\Documents and Settings\Administrator\Desktop\batchInstall_script>"C:\PsTools\psexec.exe" \\rendernode -c -f -u domain.local\rendernode -p password "Z:\installs\install.bat"
                          PsExec v1.98 - Execute processes remotely
                          Copyright (C) 2001-2010 Mark Russinovich
                          Sysinternals - www.sysinternals.com
                          C:\WINDOWS\system32>vray_adv_21001_maya2012_x64.exe -gui=0 -configFile="xml_mya2012_x64.xml" -quiet=1
                          'vray_adv_21001_maya2012_x64.exe' is not recognized as an internal or external command,
                          operable program or batch file.
                          install.bat exited on boston2 with error code 1.
                          C:\Documents and Settings\Administrator\Desktop\batchInstall_script>PAUSE
                          Press any key to continue . . .
                          At least on friday I was getting something to run.
                          I tried running the install.bat file locally on the render node and it installs fine.
                          Is there anything other than PSTools I can use?
                          Thanks,
                          Richard
                          • #43
                            Could it be permissions issue?
                            • #44
                              No do not think so. User has full system administration rights.
                              • #45
                                Are you that all drive letters have been mapped?
                                By executing cmd.exe rather than your install.bat you can try to access the file's location and see whether that's the issue or not.
                                Code:
                                Ah, great!
                                Thanks for that, Vlado!
                                Best Regards,
                                Fredrik
