rendering black!
  • rendering black!
    When I render an image , for example a car , which I render on black to be comped in, in another package It seems to take forever to render the black part of the image. I am working at 10k pixels so pretty high res & I understand the actual car geometry taking a while ( which it doesnt usually its pretty quick) but It seems to take as long rendering the black in the background.
    Is there a way to stop this or is this normal?
    Thanks
    Chris
    Hi Chris,
    Usually it render a lot faster then the actual geometry, if the environment is set to black.
    Portfolio: http://www.cgifocus.co.uk
      i have a environment light , which is set to invisible but its definatly not rendering fast. OK, so its not taking ages but I would expect it to take a split second , am i wrong? as it takes about 30-40 seconds per bucket on the black section
        do you have some high samples? I guess that could slow down the render even if invisible.
          i use the adaptive DMC & use the subdivision multiplier set to 10, which is what I usually use.
            yes, but what is your min subdivs? That is usually the issue with taking too long on blank areas. min of 2 or more is like fixed of 2 or more on those areas. Set it to 1 and it should speed up. If that's not it, I'm not sure
              min is set at 1. so ... no not sure why then.
                Do you have any render elements? What is your AA filter set to?
