quick and dirty python script to change/add vray Object id's
  • quick and dirty python script to change/add vray Object id's
    Hi guys,
    I've written a small python script to manage vray object ID attrs..
    I'm not a good programmer so it's probably full of things that can be improved, so feel free to edit as you wish.. I will improve it when I have time or feel the need but I cannot give (alot) support.. but don't hesitate to post suggestions or wishes, can't promise anything though, hope you'll understand..
    I only have maya 2011 so don't know if it works in other versions..
    NOTE:
    - don't change your selection and edit a number, because it will loop through the current selection, so if you change selection rerun the script.
    planned todo's:
    - button or field to assign same id to selected objects at once.
    - ability to give attr to procedure so you can use this for other Attr's too.
    - automatically make needed multi matte render elements..
    hope it's useful for someone!
    Last edited by tinuz; 21-10-2010, 05:48 AM. Reason: added NOTE: updated attachment
    showreel: http://vimeo.com/27236919
    Cool, thanks for sharing
      I keep getting a global name 'cmds' is not defined. I tried importing maya as cmds, and maya.cmds as cmds. I haven't fiddled much with python, so I may be doing something wrong. I'm also on 2010, so perhaps it is a pymel version thing.
      Looking at the script tho, it looks like they are all mel commands wrapped in a cmds.XXX Why not just release it as mel?
        btw, this sounds great. Would love to get it working. thanks for the effort!
          so sorry.. I have these procedures in a larger python file so I forgot to include these lines for you, just put them above the first def at the beginning of the line:
          import maya.cmds as cmds
          import maya.mel
          def changeVrayAttr():
          well I'm trying to stay off the mel, I like python much better, and as you can see I can us mel in python too ;P
            thanks for the update. I'll give it a try today.
            Andrew
