Hi all,
Ill post an example if needed but basically I'm trying out displacements in Vray and am finding that when applying a texture in the displacement of the shader group I press render and get displacement. Easy enough.
However if I lower the displacement settings really low, to the point where there isn't enough subdivision to actually displace the geometry, I still get a bump map effect on the geometry, as if I had applied my displacement map into the bump slot of the shader.
Is this intentional and if so is there a way to disable it ?
I did check a few threads but couldn't find anything mentioned on this.
Any help much appreciated.
Thanks for reading
Will
Thanks for reading
Will
