how to use in-render AO?
  • how to use in-render AO?
    I see the AO toggle in the indirect illumination controls but I can't enable it.
    Dave Girard
    Is this fixed in latest builds?
    - H -
      odd... it works for me. Well, I don't use it because render times sky rocket, but I can enable it. What build are you using?
      I do my ambient occlusion pass in post. I create a material override, using a vraylight material with a vraydirt material inside it. You can turn off GI and you'll need to disable your vraycamera exposure. In PhotoShop you use your AO pass on a new later and set it to multiple.
      I hope this helps
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090 X2
      • ​Windows 11 Pro
        I'm not referring to the V-Ray Dirt mat RE workflow. I was under the impression that enabling the AO in the settings would do it in the rendering itself, saving compositing. No?
        Dave Girard
          Yes, but slow. It should work so someone smarter them me might have to contribute.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
