File Name Prefix Layer Override not allowed?
  • File Name Prefix Layer Override not allowed?
    I tried to create a Layer Override for the File Name Prefix to have descriptive names for each of the render layers for batch render. But there is no this option as I right-mouse-click on it?
    Is this an intended behavior or a bug?
    Thanks.
    always curious...
    Hi Jason, I'm not sure about a layer-override but I always use the name tokens to embed the layer name in my file names. For example I would specify %s/%s_%l/%s_%l Then if I render with -rd x:\david\renders I get x:\david\renders\myScene\myScene_myRenderLayer\myS cene_myRenderLayer.001.exr
      Thanks for the tip, David. I'll try these tokens.
      always curious...
        this usually works for any attributes i can't set layer overrides for via the normal right-click method:
        while your current render layer is active, try this: "editRenderLayerAdjustment vraySettings.fileNamePrefix"
        i haven't done a test render, but the file name updates when you switch between render layers in the editor or globals window.
        matt
          <Version> name token doesn't work in vray?
            I don't think so. What does it do?
              It queries the Version Label attribute from the Maya renderSettings and uses this in the filename prefix.
              (We use a versioning based on the scene name btw. This way you always know where your images come from.)
                Thanks, one lives and learns Will make a note to add it.
