GI: Tree front of window
  • GI: Tree front of window
    Happy new year to all girls and boys out there!
    We have following problem: For an interior visualisation we have a simple room with two windows. Render setup: Sun&Sky, physical camera, IRmap+LC, two portal lights + several ies lights.
    In front of the windows outside we have placed several poly planes, diffuse and alpha mapped with a tree image. This gives us some nice shadows on the floor.
    Problem: As the portal lights are not simple ones, they "take its color from whatever objects are behind it." (from the VRay manual). This gives us a much nicer and more complex direct & indirect lighting solution inside the room. BUT we need to use very high settings for the IR map or very high Subdivs for the portal light to get a smooth result.
    So my question: How do you girls and boys do that? Or any tips from Chaos?
    Thanks,
    Lars
    Ah, forget it! Brain is still in holiday!
      Can you post your settings? ...and for my own work, I rarely use the portal feature of the lights.
        We changed the sample lookup and the interpolation type of the IRmap to overlapping and least squares fit. That helped a lot.
        For our last project (detailed product vis) we used Delone and Density-based. But those two needs much higher Subdivs or Noise Threshold and takes much longer to render.
          A curious approach; was it faster than doing a brute-force render?
            We had the impression that with IR+LC we get smoother (= less noise) image compared to BF. But we need to test this again.
              Well yes, of course, especially if you have relatively large flat surfaces, the irradiance map will be faster. Just curious
