What is vfbSettingsArr?
  • What is vfbSettingsArr?
    We've noticed this vfbSettingsArr attribute on the vraySettings node and are wondering what it is used for.
    It stores the configuration of the V-Ray VFB - the color curve, the exposure value, the LUT table, the state of the various buttons etc.
      Nice to know. Thanks Vlado.
        Can anyone please tell me how i can check via mel if "render region" is enabled inside the vrayvfb?
        thx a ton
        Oli
        OLIVER MARKOWSKI - Head of 3D at RISE | Visual Effects Studios
          At the moment, you can't do that easily (although you can certainly compare the vfbSettingsArr parameter for the case when it is enabled and disabled and then set it accordingly). I've made a note to add this. A work-around might be to disable the V-Ray VFB when you don't need it.
            Works perfectly for my purpose!
            thx a lot vlado!
            Oli
