How do I render out an object ID pass so Objects in the scene is colored differently for compositing ? There is no object ID renderpass only Material ID and Render ID
Object ID
Not sure if this is fixed, but if you have object ID's attached to Groups or Objects then add a VrayObject Property, the Vray Object Property will override the Object ID's and you won't get anything rendering. You will want to turn that off on the Vray Object Property node if it's being used.
this is fixed since at least 2 months....you can disable the "override object ID" in the VOP.OLIVER MARKOWSKI - Head of 3D at RISE | Visual Effects Studios
i think noone requested it, but the developers simply thought it would be a good default behaviourwhich it isn't....
maybe we hereby request the option "Override Object ID" to be OFF by default in VOPs...
cheers
OliLast edited by ultrasonic; 14-02-2011, 03:36 AM.OLIVER MARKOWSKI - Head of 3D at RISE | Visual Effects Studios
Originally posted by ultrasonic View Posti think noone requested it, but the developers simply thought it would be a good default behaviourwhich it isn't....
cheers
Oli
Thanks
DominikDominik Markota | Head of CGI | Senior Shading & Lighting TD @ Serviceplan MAKE
Originally posted by Metzger View PostWho here uses VOP object ID over-rides?
+1 from me for changing the default of the VOPOLIVER MARKOWSKI - Head of 3D at RISE | Visual Effects Studios
