sdk - creating poly and hair geometry
  • sdk - creating poly and hair geometry
    I'm not sure if this is the correct place to as such a sdk question but I could not find another appropriate forum.
    I'm trying to find a way through the examples for creating geometry during rendertime. To be honest, I find the examples a little bit complex - at least for me.
    What I want to do is to create procedural geometry for our fur pipeline.
    In mentalray I have a geometry shader which is executed at the start of rendering and creates a lot of placeholders which produce fur strands as soon as they are touched by the renderer. The fur has some per hair and per vertex informations. Now I want to implement this fur tool for vray.
    What would be great is to have an example how a single procedural hair is created maybe in such a order (if possible):
    - create a procedural which is exported from maya
    - this procedural reads some data from disk and creates all necessary fur infos and it creates all necessary procedural geometry for fur rendering at start of frame rendering.
    - the procedural wich is called as soon as the bounding box is touched by the renderer and creates the actual hair strands.
    There is an example of how to create a custom geometry plugin in the maya_plugins folder of the SDK (the vrayplane example). From then on, you can take a look at the GeomHair plugin, which is the implementation of the VRayFur plugin as well as the Maya hair rendering part, and modify them as you need.
