pure chrome reflections produce noise
  • pure chrome reflections produce noise
    Hi, I am currently working on a render and appear to have some issues with clear chrome like reflections. The model features some chrome strips and that have a VRay mtl applied with reflections set to almost 1 and glossyness also at 1. As a renderer I use the DMC sampler and the threshold is already at 0.004 - but still the chrome line shows some fine pixel noise that I can't seem to get rid of.
    Any suggestions what can be done here? I colored the piece in question red because otherwise it might be hard to differentiate from the other pieces.
    Thanks in advance, Ingo
    brave rabbit | Mac Pro 3.5 GHz 6 Core | ATI FirePro D700 | 32 GB RAM | OS X 10.13.3
    Use lower aa and higher the material subdivisions a lot!
      I am using fully adaptive control. I think adjusting the material subdivisions don't work then. Of course I can still lower my AA threshold but I am already getting pretty long rendertimes
        Turn off texture filtering in mayas file reads. Good place to start. It could reduce a lot of filtering issues as Vray does it's own filtering.
          There are not file textures related to the material in question, hence there are no filtering options. The noise just comes from reflections off a HDRI and some area lights. It's all fine in other geometry and areas. Maybe it's related to the geometry.... I have to check that
            Were you able to solve your problem? I am having the same issues and have tried changing all sorts of settings/numbers.
              I spent half my day today playing with settings to get rid of the chrome noise, and finally I found my solution. For my image sampler, I'm using Adaptive DMC, and my anti-aliasing filter I'm using Mitchell-Netravali. In the Adaptive DMC image sampler, I have my Min Subdivs set to 1 and my Max subdivs to 20. 20 was the setting that cleared all of the noise up in my chrome, now everything looks beautiful.
                Sorry for the late reply and thanks for the info. I don't quite remember how I worked around the problem. I think I somehow faked it. Next time it happens I will remember your info and give it a shot.
                Thanks and Cheers.
                  The default setting on that Max subdivs is 4 I think? So cranking that up is the magic trick I've found. Changing the sub Ds in the material did nothing for me (even cranking them up to a triple digit # just for kicks). It seems the chrome issue is not a geometry or shader problem, it's an anti-aliasing problem.
                  Cheers
                    I'd suggest it being a filter issue - trying rendering with it turned off.
