exposure help
  • exposure help
    All types of environments, VRay environment, light dome, sun & sky, are all coming out super underexposed. To test I set up a 50% gray cube with a gamma correction node at .45, lwf 2.2 gamma, srbg in frame buffer. If I set exposure on VRay physical cam with exposure control on so that the cube is around 50% gray, my environment is nearly as gray. I've gotta be missing something. Thanks!
    Did more testing. I was trying to use a light dome, or VRay environment with the exposure control ON on the camera because I was using a VRay sun. I turned the exposure control OFF and cranked the sun multiplier way down to around .002 and am getting predictable results. There is not a way to add an exposure control only to the VRay sun? Am I on the right track?
      You must do just one thing first and that is to apply a Vray physical camera, then I will work more predicable.
      Ludwig
