Get output image name with python
  • Get output image name with python
    Hi!
    Is there a way to get the resolved image name from the vraySettings with python? From Maya Software you can get it with
    name = renderSettings(firstImageName = True, fullPath = True)
    for example.
    Thanks!
    Yep, something like this:
    Code:
    from vray.utils import *
    p=findByType('SettingsOutput')
    dir=p[0].get('img_dir')
    fname=p[0].get('img_file')
    print dir+fname
      Very interesting, thanks !
      In my test, I get this result in the logs :
      O:/TEMP/TEST/images/testVray/masterLayer/testLay.tiff
      O:/TEMP/TEST/images/testVray/layer1/testLay.tiff
      O:/TEMP/TEST/images/testVray/layer2/testLay.tiff
      So, it is executed once for each render layer.
      Note that it's not executed once for each frame, which explains why I get testLay.tiff instead of testLay.0023.tiff
        Yes, the Python script is currently run only once before rendering a layer begins. We might have to add a separate callback between frames.
          Looks good, thank you! Ist vray.utils documented somewhere?
            There is the documentation concerning the python part here: http://www.spot3d.com/vray/help/maya...ene_access.htm
            For information about all the different types of plugins and their parameters, you can look at .vrscene files exported from V-Ray for Maya, and you can also use the plgparams tool from the SDK.
              Thanks again!
                I get a Fatal Error when I do this in Maya2012 HF2 with vray 2.10.01 when the funtion gets called. Any ideas?
                EDIT: With Maya2011 SP1 and the Vray 2.00.04 Release I also get a Fatal Error.
                I'm on windows7, btw.
                  There is a problem in the recent nightly builds; should be fixed for the build tomorrow.
                    I just checked the latest nightly build. But I still get the Fatal Error.
                      Yes, sorry didn't get there yesterday (we had to move to a new office); I will let you know the revision number when it's fixed, hopefully a bit later today.
                        Hm, on my machine the crash was caused by a wrong copy of vrayformaya.mll being loaded by the python module. The crash went away after I removed the duplicate version.
                          Hm, okay. What was the problem last time?
                            It's been the same problem for me; can you get me the crash dump from Maya? (It's in the %temp% folder, MayaCrashLog*.dmp)
                            • #15
                              Here it is:
                              MayaCrashLog110712.1920.log.zip
