VRAY_AUTH_CLIENT_FILE_PATH on Linux
  • VRAY_AUTH_CLIENT_FILE_PATH on Linux
    I'm trying to add the env VRAY_AUTH_CLIENT_FILE_PATH to my Maya launch script but I can't find the "vrlclient.xml" file on Linux. I've searched the various Vray and Maya directories.
    Where does this file live? Is it generated by the rpm install? What does a sample vrlclient.xml look like?
    I'm assuming this is an important env to set, correct?
    Thanks!
    You can find it in the ~/.ChaosGroup/ directory.
    The file is generated by the tool setvrlservice.exe (it is in the vray/bin directory).
    I think there is some information how to use it in the install document comming with the installation.
    /Teodor
    V-Ray developer
      Thanks! Found it.
      The install docs do mention the file, but they don't state where it lives, but it should!
      Appreciate the help,
      Rich
