Mel call to DR slave nodes
  • Mel call to DR slave nodes
    Hello, quick question here. Does anyone have any mel script advice /syntax for checking whether a DR node is "live"?
    I find that often after a Maya crash the DR slave nodes have also crashed on other machines. I'd like very much to script up an event based slave check (probably on startup).
    You can write a small wrapper around the render server on the render slaves that just restarts it if it crashes (i.e. calls vray.exe in a continuous loop).
      Thank you Vlado. That sounds like a superb idea (really!). The only problem is my "code" knowledge only stretches as far as rudimentary mel scripting.
