Hey guys, I'm a bit confused about 'view dependent' & the edge length and the relationship between each other.
Does edge length work with 'view dependent' checked on or off ?
I'd like to know if turning off 'view dependent' is a bad idea, and if I'm getting some sharp instead of smooth edges which way should the number on edge length be going if that's controlling it ?
Obviously I've looked at this article:
http://www.spot3d.com/vray/help/maya...rib.htm#Subdiv
But I found it a bit confusing under the View-dependent & Edge length sections
