How to turn VRayFur "Primary Visible" OFF
  • How to turn VRayFur "Primary Visible" OFF
    Hey Guys,
    call me stupid, but i haven't found a way to change renderstats like "primary visible" or "matte Surface" on a VRayFur.
    Where do i find it?
    cheers
    Oliver
    OLIVER MARKOWSKI - Head of 3D at RISE | Visual Effects Studios
    Select the V-Ray fur preview in the viewport and then add the regular V-Ray object properties to it. You can then change the parameters of the V-Ray properties as you wish.
    Another option is to adjust the "Primary visibility" option of the V-Ray fur preview node itself.
      thx...i was just confused cause i thought the FurPREVIEW is just for Viewport PREVIEW
      Damn! I just overlooked this...
        I have a question about primary visibility.
        The primary visibility always works with transparency or you will change this ?
        Because obviously, with a lot of Fur (or objects), this will fail (with primary visibility with transparency).
        Thank you Vlado.
        www.deex.info
          Currently it works as transparency; this will change, but I cannot say when for the moment.
          You can increase the max. transparency levels in the V-Ray global settings to work around this.
