If I have 2.2 set as the gamma in the colour mapping roll out menu in the render global, should I be switching on the sRGB lookup in the vray frame buffer too?
You must to switch on the sRGB lookup if you enable : Don't affect colors, in the color mapping. You must to check this if you render with a linear format (like exr).
If you render a srgb format (like jpg), you dont neeb to enable the Don't affect colors, so, dont need to swtich the sRGB lookup.
