Texture baking via command line
  • Texture baking via command line
    can you bake textures via command line ? I would love to do texture bakes on our render farm but I dont see any options for command like texture baking.
    CG supervisor
    Alkemy-X
    Yes, you can use the following commands:
    -bake_node name Specify object to bake render
    -bake_map name Which UV set to use
    -bake_padding float Edge padding in pixels
    For example:
    render -r vray -bake_node pCone1 -bake_map map1 scene_x.mb
    To display a detailed list with common options you can type:
    Render.exe -r vray -help
