Return RenderElement-nodeName with Mel procedure vrayAddRenderElement
  • Return RenderElement-nodeName with Mel procedure vrayAddRenderElement
    Hi Guys,
    just FYI...it would be great for scripting if you could return the nodeName of a newly created RenderElement...i just hacked your mel...its just some minor changes...maybe you could implement it in the next releases...
    Code:
    // $index is the index in the vrayRenderElementsNames and vrayRenderElementsLabels arrays
    global proc string vrayAddRenderElementImpl(int $ind) {
        global string $vrayRenderElementsNames[];
        global string $vrayRenderElementsLabels[];
        string $node;
        if ($vrayRenderElementsNames[$ind]=="LightSelectElement") $node=`createNode VRayRenderElementSet`;
        else $node = `createNode VRayRenderElement`;
        string $newName = "vrayRE_" + $vrayRenderElementsLabels[$ind];
        // Maya would do this automatically, but produces some warnings.
        $newName = `substituteAllString $newName " " "_"`;
        $newName = `substituteAllString $newName "-" "_"`;
        $node = `rename $node $newName`;
        string $endingNum;
        if (size($node) != size($newName)) $endingNum = `match "[0-9]*$" $node`;
        addAttr -ln "vrayClassType" -dt "string" $node;
        setAttr -type "string" ($node+".vrayClassType") $vrayRenderElementsNames[$ind];
        addAttr -ln "enabled" -keyable true -at "bool" -dv 1 $node;
        int $j;
        for ($j = 0;; $j++) {
            string $buffer[] = `vray getAHint "RenderElement" $vrayRenderElementsNames[$ind] ("attribute_" + $j)`;
            string $attrName = $buffer[0];
            if (size($attrName) == 0) break;
            vrayAddAttr($node, $attrName);
            // If we have more than one RE of the same type - change the suffix so that different output files are created.
            $buffer = `vray getAHint "RenderElementAttribute" $attrName "vray_parameter"`;
            string $vray_parameter = $buffer[0];
            if ($vray_parameter == "name" && $endingNum != "" &&
                $vrayRenderElementsNames[$ind] != "ExtraTexElement" && $vrayRenderElementsNames[$ind] != "MaterialSelectElement") {
                string $currentVal = `getAttr ($node+"."+$attrName)`;
                setAttr -type "string" ($node+"."+$attrName) ($currentVal+$endingNum);
    [B]    return $node;[/B]
    global proc string vrayAddRenderElement(string $renderElementName) {
        // Make sure the global arrays with the elements names/labels have been loaded, as the UI may not have been created yet
        vrayLoadRenderElementsGlobalArrays();
        [B]string $node;[/B]
        // Find the location of $renderElementName in the $vrayRenderElementsNames array
        for ($i=0; $i<size($vrayRenderElementsNames); $i++) {
            if ($vrayRenderElementsNames[$i]==$renderElementName) {
                [B]$node=[/B]vrayAddRenderElementImpl($i);
                updateListExistingElements(1);
                return [B]$node[/B];
        warning("Render element with name " + $renderElementName + " not found !");
    OLIVER MARKOWSKI - Head of 3D at RISE | Visual Effects Studios
    This is already implemented since a long time in the nightly builds.
      Damn....sorry for that...but unfortunately i cannot work with nightlies at the moment but i thought i am
