Note: I am posting this in the maya section, but the potential workaround I have found is only available in 3dsmax (skylight portal for VrayDomeLight). All the image below were rendered using 3dsmax.
It would seem I cannot get the correct result in my Global Illumination render element when using the VrayDomeLight. There seems to be additional light information included in the global illumination that, correct me if I'm wrong, is incorrect. It is affecting both the Global Illumination render element and the final 'Beauty' frame.
I have found a potential workaround, enabling 'Skylight portal' for the domelight, however this option is not currently available in maya (only 3dsmax), and we need to find a solution in maya.
Please find some images attached below that illustrate what I'm talking about, all renders using the same VrayDomeLight with a generic HDRI, only setting that was changed was use 'Skylight Portal.
Beauty - Skylight Portal = Off
Beauty - Skylight Portal = On
GI - Skylight Portal = Off
GI - Skylight Portal = On
GI - Difference between - Skylight Portal = On + Skylight Portal = Off
