1 or many lights
  • 1 or many lights
    Hi everyone
    I am sure this has been covered before, but any input would be great
    I am rendering a parking garage scene with a car.
    I would like to simulate numerous neon tubes on the ceiling
    Should I use 1 huge Rect Light that covers the ceiling using a gel to simulate the neon tubes, or several smaller Rect Lights with individual light gels?
    What would give a decent result with faster render times?
    Thanks!
    It depends on the number of lights, I guess it would best to make a few tests what would work best in your case.
      Hi Vlado
      If there are 20 lights...what would be the best way to go (if you had to take a guess!)
        not that guessing would make much difference (you should test it)... but I would probably go with 20 lights. Small areas with lower sampling seems better to me than 1 large area light with a ton of samples (adaptive or not). more control. Maybe the BG lights could go with lower samples. I dunno, more options to optimize if you need to.
        Andrew
          Thanks for the input
          I will try both and post the results here for reference!
