Hi there,
I am currently tweaking some render settings and found some unexpected behaviour regarding the max depth value under a vray material's reflection settings.
My assumption always has been as follows:
when changing the max reflection depth of a material, say "steel", it only has an impact on the objects assigned with the material "steel". No other objects are influenced.
steel's max reflection depth = 1: an object assigned with the material "steel" only reflects the surrounding objects
steel's max reflection depth = 2: an object assigned with the material "steel" reflects surrounding objects PLUS the (first) reflections in these objects...
and so on...
Anyways, when tweaking some renderings it just ocurred to me that Vray seems to behave differently. Please have a look at the attached image. When changin the max reflection depth on the steel material, it has an impact on the material made of plastic. Has my assumption been wrong or does Vray behave in a strange way here? If this is the way it is supposed to be it makes tweaking renderings way harder in my opinion as you never know what objects you will influene when setting up a certain material.
I am grateful for any explanations.
Thanks,
Matthias
V-Ray for Maya version 2.10.01, revision 18083 from Dec 11 2011
and so on...
Thanks,
Matthias
