I've just run in problems with Maya fluids (Maya 3D fluid container with emitter , maya shader ..., Phoenix plugin not even activated on master machine, in fact since the Vray build 22501_19818 has been installed Phoenix doesn't load anymore) and Vray D.R , slaves produced black buckets, after investigation I found that the slave where I did install Phoenix yesterday was rendering well and the consoles confirm this :
On a slave where phoenix has been installed :
On a slave without Phoenix installed :
Master :
MacPro Octo Cores - 32 Go - under Bootcamp - Win 7 pro - Maya 2012 Adv. Pack - Vray_adv_22501_maya2012_x64_19818.exe -Phoenix 2.0.0 (if Vray 1st Feb build installed)
Render Farm : 10 nodes : Xeon 8 cores - 24 Go.
[PhoenixSimPlugin] Frame data successfully loaded from .
[PhoenixSimPlugin] grid 66x66x66, time 0
warning : Failed to create object of type "PhoenixFDSinVOl"
warning : Failed to create object of type "PhoenixFDSim"
warning : Failed to create object of type "PhoenixFDSTexAlpha"
warning : Failed to create object of type "PhoenixFDCache"
