bitmap buffer and BSDF
  • bitmap buffer and BSDF
    I´ve these warnings since a view days. (2012, Vray 2.2 official)
    And realy often the RT engine slaves crashes.
    What is the bitmap buffer?
    What is BSDF?
    The scenes are original rendered with Mental Ray and I moved them to Vray.
    Something wrong in my scenes?
    Thanks
    Vray 3.5, Win10
    www.3dcompani.com
    It was a bug; as always if you need the fix please email me to vlado@chaosgroup.com
      thanks Vlado,
      I will see what happens here.
      Isnt there a newer stable Version of 2.2?
      Jörg
      Vray 3.5, Win10
      www.3dcompani.com
        Nope, as the only differene between the 2.1 and the 2.2 versions is that for 2.2 there is a GUI installer on Mac OS X and the .exe extensions are removed for executable files on Linux and Mac OS X. If you are on Windows, they are practically the same.
          i recently got this error on a job. warning [TexBitmap] No bitmap buffer specified. then the render completes without rendering the frame. is this part of the same bug?
          CG supervisor
          Alkemy-X
            No. The bug described above was specific to V-Ray RT only and happened because the render server attempted to render the scene before all the scene change commands were received.
            Your bug is most probably related to the V-Ray for Maya translator, although I don't know right away what is wrong with it. If you have a scene that you can send to vlado@chaosgroup.com it will be helpful.
