RT - save to animation?
  • RT - save to animation?
    Can RT save its frames as an animation like they can in Max?
    /Bard
    www.hellobard.com
    Norwegian Broadcasting Corporation (NRK) - Motion graphics artist
    Only if you export a .vrscene and render through V-Ray Standalone...
      That's too bad... It's a bit cumbersome to use standalone just to do quick animation tests.
      Thanks vlado.
      /Bard
      www.hellobard.com
        I actually remembered there was a script that did this... let me try to find it...
          Ah yes, there it is: http://polygonspixelsandpaint.tumblr...ost/6388153858
            ya, I wrote V-Ray Tuner and that script works. Vlado helped me integrate the commands to write the individual frames. Just set your frame range in the Render Settings, set a max time for RT frames (can be set at the bottom of V-Ray Tuner) panel and select RT Multiframe Render Script from the RT menu.
            Dave Girard
