Bloom
  • Bloom
    I am having a look at the bloom option in the VFB. However, I get the message: "No Channel, please prerender".
    How do I pre render?
    Any link to tutorial about using the bloom effect in Maya?
    Thanks,
    Yannick
    Portfolio: http://www.cgifocus.co.uk
    never mind, i had to close the VFB and start a new render.
      The lens effects need to operate on the colors in physical space; if you have any color mapping on your image, you'll need to re-render so that the lens effects can store the physical colors and use them later on to generate the bloom/glare.
        Actually it should say "re-render", not "prerender" Will fix it.
          Cool thanks Vlado.
            Does this work in Batch now, a couple of weeks ago, V-Ray did not seem to output a channel in a batch render, nore a glare intensity mask either.
            But the bloom worked fine in the VFB.
            Maya 2020/2022
            Win 10x64
            Vray 5
              We are working on the render elements issue in batch mode.
              Thank you for the feedback.
              Zdravko Keremidchiev
