set Render Element Separator via mel
  • set Render Element Separator via mel
    I try to set the render element separator via a small mel script (in my case to "_"). Can you tell me the attribute or function I have to use?
    I just got "vrayChangeRenderElementSeparator;" via "echo all commands"-function and don't know, how to use it.
    Thanks!
    Janosch
    You can use this code to change render element separator from your MEL script:
    string $separator = "_";
    if (`objExists vraySettings`) {
    setAttr "vraySettings.fileNameRenderElementSeparator" -type "string" $separator;
    Only the first character from $separator string will be taken into account, also it must be valid filename character.
    V-Ray for Maya developer
      nice, thank you.
      one thing left: now in the render settings the old separator is displayed. i only can check the "real" active separator via getAttr
      how to avoid this?
