Hi there,
I'm trying to launch various vrayslave versions in parallel so that we'll be able to use DR from any deployed vray on our system. Actually we have a vray 15001 for old productions, 22001 is our current stable release, and 22501 is deployed for test purposes. Each vray is installed in a separate network share (/Network/Applications/ChaosGroup/maya_XXXX/vray_YYYYY), and I'm using a python script to walk these folders and launch each available slave using it's version as port number, ie :
/Network/Applications/ChaosGroup/maya_2012/vray_15001/vray/bin/vray -server -portNumber=15001 >> /tmp/slave_maya_2012_vray_15001.log
/Network/Applications/ChaosGroup/maya_2012/vray_22001/vray/bin/vray -server -portNumber=22001 >> /tmp/slave_maya_2012_vray_22001.log
/Network/Applications/ChaosGroup/maya_2012/vray_22501/vray/bin/vray -server -portNumber=22501 >> /tmp/slave_maya_2012_vray_22501.log
It works fine with vray 15001 and 22501, but the 22001 fails arguing that a vray server is already running :
VRay 15001
VRay 22501
VRay 22001
Any tip would be greatly appreciated, I can't understand why it's working with two servers, and broken with the third one !
Here is my python script to detach the various slaves :
Tonio
VRay 15001
Code:
[2012/Dec/13|12:58:28] Reading configuration from "/Network/Applications/ChaosGroup/maya_2012/vray_15001/vray/bin//vrayconfig.xml" [2012/Dec/13|12:58:28] =============================================== [2012/Dec/13|12:58:28] V-Ray Standalone, version 1.5.01 for x64 [2012/Dec/13|12:58:28] Copyright (C) 2000-2010 Chaos Group Ltd. All rights reserved. [2012/Dec/13|12:58:28] Use -credits option for additional third-party copyright notices. [2012/Dec/13|12:58:28] [2012/Dec/13|12:58:28] Build from Apr 28 2011, 02:51:46 [2012/Dec/13|12:58:28] Compiled with GCC-compatible compiler, version 4.2 [2012/Dec/13|12:58:28] Operating system is Mac OS X [2012/Dec/13|12:58:28] [2012/Dec/13|12:58:28] V-Ray core version is 2.00.01 [2012/Dec/13|12:58:28] =============================================== [2012/Dec/13|12:58:28] [2012/Dec/13|12:58:28] Loading plugins from "/Network/Applications/ChaosGroup/maya_2012/vray_15001/vrayplugins/libvray_*.so" [2012/Dec/13|12:58:28] Finished loading plugins. [2012/Dec/13|12:58:28] Entering server mode - waiting for render requests on port 15001. Press Ctrl+C to exit.
Code:
[2012/Dec/13|12:58:28] Reading configuration from "/Network/Applications/ChaosGroup/maya_2012/vray_22501/vray/bin//vrayconfig.xml" [2012/Dec/13|12:58:28] =============================================== [2012/Dec/13|12:58:28] V-Ray Standalone, version 2.25.01 for x64 [2012/Dec/13|12:58:28] Copyright (C) 2000-2010 Chaos Group Ltd. All rights reserved. [2012/Dec/13|12:58:28] Use -credits option for additional third-party copyright notices. [2012/Dec/13|12:58:28] [2012/Dec/13|12:58:28] Build 22390 from Sep 26 2012, 15:56:50 [2012/Dec/13|12:58:28] Compiled with GCC-compatible compiler, version 4.2 [2012/Dec/13|12:58:28] Operating system is Mac OS X [2012/Dec/13|12:58:28] [2012/Dec/13|12:58:28] V-Ray core version is 2.00.02 [2012/Dec/13|12:58:28] =============================================== [2012/Dec/13|12:58:28] [2012/Dec/13|12:58:28] Loading plugins from "/Network/Applications/ChaosGroup/maya_2012/vray_22501/vray/vrayplugins/libvray_*.so" [2012/Dec/13|12:58:29] 109 plugin(s) loaded successfully [2012/Dec/13|12:58:29] Finished loading plugins. [2012/Dec/13|12:58:29] Entering server mode - waiting for render requests on port 22501. Press Ctrl+C to exit.
Code:
[2012/Dec/13|13:00:51] Reading configuration from "/Network/Applications/ChaosGroup/maya_2012/vray_22001/vray/bin//vrayconfig.xml" [2012/Dec/13|13:00:51] =============================================== [2012/Dec/13|13:00:51] V-Ray Standalone, version 2.20.01 for x64 [2012/Dec/13|13:00:51] Copyright (C) 2000-2010 Chaos Group Ltd. All rights reserved. [2012/Dec/13|13:00:51] Use -credits option for additional third-party copyright notices. [2012/Dec/13|13:00:51] [2012/Dec/13|13:00:51] Build from Feb 1 2012, 11:11:21 [2012/Dec/13|13:00:51] Compiled with GCC-compatible compiler, version 4.2 [2012/Dec/13|13:00:51] Operating system is Mac OS X [2012/Dec/13|13:00:51] [2012/Dec/13|13:00:51] V-Ray core version is 2.00.01 [2012/Dec/13|13:00:51] =============================================== [2012/Dec/13|13:00:51] [2012/Dec/13|13:00:51] Loading plugins from "/Network/Applications/ChaosGroup/maya_2012/vray_22001/vray/vrayplugins/libvray_*.so" [2012/Dec/13|13:00:53] 102 plugin(s) loaded successfully [2012/Dec/13|13:00:53] Finished loading plugins. [2012/Dec/13|13:00:53] error: There is another server already running. [2012/Dec/13|13:00:53] Exiting server mode. [2012/Dec/13|13:00:53] Closing log - 1 error(s), 0 warning(s).
Code:
#!/usr/bin/env python import sys import os import re import signal import subprocess import shlex import time processes = list() def kill_handler(signal, frame): global processes print "main process killed" for p in processes: print "killing " + str(p.pid) p.kill() sys.stdout.flush() sys.exit(0) def detach_slaves(): global processes print "launching slaves" if not "MM_APPLICATIONS_PATH" in os.environ: print "ERROR: cannot find MM_APPLICATIONS_PATH in environment variables ..." sys.exit(126) chaos_base = os.path.join(os.environ["MM_APPLICATIONS_PATH"], "ChaosGroup") print "--" for maya in os.listdir(chaos_base): if re.match("^maya_([0-9]+)$", maya): maya_base = os.path.join(chaos_base, maya) print "- " + maya_base for vray in os.listdir(maya_base): match = re.match("^vray_([0-9]+)$", vray) if match: port = match.group(1) cmd = os.path.join(maya_base, vray, "vray", "bin", "vray") cmd += " -server -portNumber=" + str(port) + " >> /tmp/slave_" + str(maya) + "_" + str(vray) + ".log" print cmd processes.append(subprocess.Popen(cmd, shell=True)) sys.stdout.flush() def watch_kill(): signal.signal(signal.SIGTERM, kill_handler) signal.signal(signal.SIGINT, kill_handler) while True: signal.pause() if __name__ == "__main__": detach_slaves() watch_kill()
